rumproast789 Posted February 20, 2009 Report Posted February 20, 2009 Are these any good? the amp I'm getting, an AQ2200d requires a 200 amp fuse, and im using 2/0 welding cable so i figure il ljust get five, best bang for my buck and in case any pop i'll have an extra http://cgi.ebay.com/Tsunami-200-Amp-ANL-Fu...bayphotohosting And for a fuse block/holder, should I use the typical screw down the cable, or should I get the ones that you use a wire terminal on each end and just touch the fuse together? Have any suggestions on some? I need 2 affordable ones, but 3 if they are REALLY affordable.. I'm not trying to cheap out, but I just don't think its necessary to spend 75$ on three fuses... 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
SundownTL3.2 Posted February 20, 2009 Report Posted February 20, 2009 ANL fuse holders 2004 Chevy Tahoe LT........... THINKING
rumproast789 Posted February 20, 2009 Author Report Posted February 20, 2009 ANL fuse holders Yeah, don't both the ones I said come as ANL fuse holders? THe ones I saw all looked similar and held ANL fuses I was reading the ebay listing, and it said the ones pictured are nickel, but the ones I'm getting are gold, is that good? What I mean is, do you think it's fake gold... Nice car by the way, explorers ftw (since I'm using 2/0 thats why I'm wondering because most are 0 guage fuse holders) 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
sully Posted February 20, 2009 Report Posted February 20, 2009 Tsunami makes an OK product, those look like the cheep ones so they will be very easy to bend and or break. 2003 Ford F-150 Reg Cab layin body on 26's 2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine. 2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's 2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
rumproast789 Posted February 20, 2009 Author Report Posted February 20, 2009 Tsunami makes an OK product, those look like the cheep ones so they will be very easy to bend and or break. Well damn, I hope not What do you all think of these fuse holders? http://cgi.ebay.com/IN-LINE-ANL-FUSE-HOLDE...DefaultDomain_0 2002 ford explorer 200 amp rewound alt single 18" Fi btl fully loaded 2 1750's 2 c&d tech 88amp/hr batts 2 ought wiring cdt component set up front, cdt coaxials in back Kenwood eXcelon KDC-X693
