im thinking about covering a few pieces of my truck interior and im thinking about using crushed velvet. im wondering what u guys think of the stuff, is it flexible does it form to stuff good and what kind of glue whould i use to stick the stuff on the pieces
Most of that fabric is stretchy too so it'll conform to complicated pieces if you place and stretch correctly. Only thing you gotta look for is "runs" in the fabric (similar to nylon) that you can't see until you stretch the piece you're wrapping with. Other than that, it's great to work with.
I use Loctite Super Adhesive Permanent. It's $14 a can, but it does the trick. Just follow directions on it for the best adhesion and works on anything.
Need an install? Hit me up.
[email protected]
what do u mean by a run in the fabric
run is like a weird stretch in the fabric that kinda leaves a little stretch of whatever is behind it showing through, think of when a girl tears her nylons, or you suck up a thread in a carpet. basically when yous stretch it you'll have a line with the substrate showing through.
Team DC
is there anyway u can prevent it on fix it
Just check for it before you apply it. Worst case scenario, you miss it and just tear it off and try a new piece. It won't just happen while sitting there.
[email protected]
does it happen often that there is a run in it
whould 3m 90 spary on glue work or is that i little over kill
it just happens, its silly, im not too sure why, but sometimes you can just kinda tug it a certain way and you'll notice it.
i've used 3m super 77 doing like normal carpet/suede/vinyl and had no problems, 90 couldnt hurt for the extra lil bit it costs
Team DC
  • Who's Online   0 Members, 0 Anonymous, 523 Guests (See full list)
