Torres' Box Tuning Calculator - Updated 8/18
Torres
are you in a country that uses metric by default?
I remember some weird bug with non-imperial systems causing issues when using torres and using imperial.
i ask because you have commas in your numbers which is an indicator of non imperial, here in the states we uses periods for decimal points.
yes ı tried , this time it shows gross volume accurate but port disp is about same , ıt shows port disp like 28 litres: 1 ft3 , 56 litres : 2 ft3 but still ı cant see remainder part...ı designed a box that port disp is about 42.5 litres (1.5 ft3 ) but it shows as 28 litres (1 ft3 ) .....strange
I'm trying to make a 2.5ft^3 box tuned at 33Hz - 34Hz.
Box 1 (33Hz):
Box 2 (34Hz):
In box 1 I adjusted until Gross Volume was 2.5, and in box 2 I adjusted until Net Volume was 2.5. Which one is correct?
Also, is the Physical Port Length the length of the port wall on the inside of the box?
Does the correct version of the box look good?
I'm trying to make a 2.5ft^3 box tuned at 33Hz.
Here is what I came up with:
My questions are:
Do I make it so the Gross Volume is set to 2.5ft^3, or the Net Volume?
Is the Physical Port Length the length of the port wall on the inside of the box?
u want the net volume to be 2.5 also with a port that small youre going to get port noise so make the port more like 2.5-3"
Chick took 3 shots of Jager, and then, pissed in my mouth.. oh.. wait.. naw.. that wasnt weird..
He probably tearin dat ass up every night. Reason for "insomnia" Ain't sleeping cause he's like a horny hamster on coke.
2000 grand prix gtp: SOLD My Home Theater Build (working progress) 2002 accord coupe
subs: 2 soundqubed hds300 12s 4'1" towers tuned to 29hz sub: AQ hdc3 12
Amp: pioneer gm9061 amp: poineer gm9601
headunit: kenwood kdc 255u mids: SQ pro mids
midbass: polk db 8s highs: stock
mids/highs: shitty off brand
Thanks man. I fixed it up. How does this look?
I made the box in AutoCAD. I read your port length explanation several times, but I'm still confused about what it means. I made the inside port wall length 28.25" as I entered into Torres. Is this correct?
.75" + 13.5" + .75" + 13.25" = 28.25"
  • Who's Online   0 Members, 0 Anonymous, 1798 Guests (See full list)
