for the rear hatch add expanding foam if its the plastic interior piece that is rattling, do not overdue it and have some wd40 or something to cleanup what oozes out....for the glass if it opens then add a stip of weather strippiing from osh around the window where the actual seal touches....there will be a seal on the door, and you are going to add an additional one around on the glass...thats what i did.
ok man
will do!!!
so on out of window or just on inside were touches???
2004 Chevy Tahoe LT........... THINKING
Go to Home Depot and get some rubber window seal strips and place that around the window. Get the hollow strips so the rubber has some give to it so the window seals nicely. It helped me out pretty good. Im againist the foam sh**! I’ve never tired it and never will. I’ve seen enough people to laugh at that have used it that I will never try it.
Edited by spl explorer
Rollerz Only - Sacramento Chapter. 6 Time Lowrider Magazine club of the year
94 Xploder on 22s - Gutted for now...
87 Cadillac Fleetwood Brougham on hydros, fully euroed out Tookie blue
*ROLLERZ ONLY MAFIA*
Crankin the volume knob and hittin switches.
http://www.rollerzonly.com
does lowes carry it?? we unfortunately dont have h/d
Im sure they do. Go into the window/ door area and ask for weather stripping.
just do the outside line of the window with .5" wide weather stripping but not the thick thick shit and just do where the window touches the inside of the hatch and the hatch itself
so you can still see out the window and keep it clean
haha hers a shitty pic,
Edited by uhoh_45
R.I.P!
(Nov-29-2009)
92 explorer
current build
ik what your talkin about what i was going to do is strengthen the latch make it so tight it cant rattle and add more latches along the bottom.
The set up your talking about would sound great in my Tahoe. Trade you my dog for it. He has one eye but that only makes for bad depth perception so hey so what if he is running into shit, look at it this way he is easy to sneak up ninja style on. (right side only)
</div>
  • Who's Online   1 Member, 0 Anonymous, 511 Guests (See full list)
