IAMBUMP Posted February 25, 2009 Report Posted February 25, 2009 So a parallel 4link with a panhard bar or a triangulated 4link. If lift is an issue, I'd say the triangulated 4link. The parallel 4link with the panhard will move the rear end to the side. A lot of people have been running Watts links, which work well when setup properly. The Suicidedoors 5 link, like already mentioned, is a great piece. My old roommate has that setup in his S-10 and it's great. Well worth the $$$$. this is why you find a reputable high quality shop with someone that knows more about suspension than just laying our a truck. they ARE around, but few and far between. If setup properly a panhard will work just as good as anything else. Problem is minitruckers have this infatuation with having ridiculous amounts of lift, i have no idea why. Corvettes are 4 inches off the ground at all times, why do you need more than that? my ride height is setup at 3 inches off the ground, thats body dropped and I really doubt I go over 6 at any given time....i am building my truck to ride low, not up high with the donks. a panhard setup at half travel will work just as well as anything else. your worst option would be to run a 50/50. the axle literally twists forward/backward depending on position in the travel. not good. If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
Gearstix Posted February 25, 2009 Author Report Posted February 25, 2009 I have a camper shell. It'll be painted the color of my truck, once the truck is repainted. I could always mount the fuel cell at the back of the bed in front of the tailgate, but then I have 0 bed space. Where am I supposed to put the beer? 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
IAMBUMP Posted February 25, 2009 Report Posted February 25, 2009 I have a camper shell. It'll be painted the color of my truck, once the truck is repainted. I could always mount the fuel cell at the back of the bed in front of the tailgate, but then I have 0 bed space. Where am I supposed to put the beer? in your body's fuel tank! duh! If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
IAMBUMP Posted February 25, 2009 Report Posted February 25, 2009 are you bulding it to use the bed AND the topper or JUST the topper? why not build a tonneau out of 1x1x1/8 sq tubing? build it so it sits flush with the bed rail, and it would bea very solid "floor" for your system to sit on, and you can drop your tailgate still to load up the bed with beer, seats for shows, wood for a new box...whatever... If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
Gearstix Posted February 25, 2009 Author Report Posted February 25, 2009 are you bulding it to use the bed AND the topper or JUST the topper? why not build a tonneau out of 1x1x1/8 sq tubing? build it so it sits flush with the bed rail, and it would bea very solid "floor" for your system to sit on, and you can drop your tailgate still to load up the bed with beer, seats for shows, wood for a new box...whatever...Lol. This was my plan, and build a frame for the box to sit on, then all the air management and stuff will sit under the box. its the only way I can think of doing everything I want, without selling this thing and buying an ext cab. 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
Gearstix Posted February 25, 2009 Author Report Posted February 25, 2009 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
IAMBUMP Posted February 25, 2009 Report Posted February 25, 2009 why are you so set on mounting everything in the bed? you have a lot of room on the frame to mount stuff... If you've been doing something for 20 years, does that mean what you do it right??? __________________________________ Want: 2x Phoenix Gold RSD65CS Comp Amp Undecided AA Havoc AQ 1200 knu wiring set scew lugs for all connections Alpine IDA-X303 2v preout --this goes under the seat. Have: Alpine tape deck w/ Benzi Box and 6 disc changer Check out my Toyota build
Gearstix Posted February 26, 2009 Author Report Posted February 26, 2009 Will there be any issues with the tank behind the axle dragging? 2005 Blazer Build... Mach 5 SPL-12s, Audiopipe AP3000.1D..
*1LOWSUV* Posted February 26, 2009 Report Posted February 26, 2009 lol, again it may work, but its not right. Just because you do something for 20 years doesn't mean you know everything. I'm tired of minitruckers building half ass crap when the right way doesnt cost but a LITTLE more Hey dickhead...I had mini trucks while you were still in diapers....I was "into" mini-trucks in the 80's ...ya know when they first started popping out. I'm into real estate, Street Rods, and Choppers now and I have a few toys like my bagged dime. I know what I'm doing...been doing it abit longer then most so keep your "I'm always right Knowledge" to yourself... It works...its done right...I have no problems...For the record...the right way would be to lift it with 4 pumps and 10 batteries but I put bags in it because they were free. http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif [email protected]
*1LOWSUV* Posted February 26, 2009 Report Posted February 26, 2009 I'm tired of minitruckers building half ass crap when the right way doesnt cost but a LITTLE more Says the guy with the primered truck that is 4g's and 2 trucks into it.... http://www.stevemeadedesigns.com/board/public/style_emoticons/default/dirol.gif [email protected]
