Crump Posted February 24, 2009 Report Posted February 24, 2009 Well i heated up the terminal from the back right below the hole, and pushed the solder in from the other side. Well it didn't really do the things in the videos and pics, mine didnt do that. It went through down the wire and melted the plastic coat. And the top didnt really turn out it was clumpy and the ring was pretty much burnt. Any tips on how to fix this, i know it takes practice, but i really need it done by thursday. thanks Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
aznboi3644 Posted February 24, 2009 Report Posted February 24, 2009 takes practice...you gotta learn to modulate the heat and let off so it can cool down a bit at times and change where you are placing the heat.
zfrerichs Posted February 24, 2009 Report Posted February 24, 2009 if you cant rip the terminal off then its doing its job, you wont get it to look pretty without practice. Roseville, CA
