Kicker L5 Box
alaskanbass
so i have two kicker L5 8's and i wanna make my box 30x16x10 with the port 3.5 wide.. i made up a design on RE audios site calc. with that it was at 1.405 cubes at 36hz.. does that sound pretty good.. or should i do somethin else.. theyll be runnin of a kicker zx750.1. and goin into a neon.
clarion cz500 head unit
Kinetik hc600
2 level 3 15s in a 4th order
mb quart 1500.1 (for now untill i get a dc 1.2k)
all knu konceptz wiring
in a 2009 ford flex
-DISKOLORED AUDIO-
-Authorized Dealer for DC Soundlab in Alaska-
Is that after or before displacement of the woofer?
before im guessing. re audios site makes jus regular L port boxes.. should this be a good design for the L5's
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
see this is what i was talkin about a reg ported box
1.405 cubes @ 36hz..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
does that atleast look like a good box.. for two L5 8's off a zx750.1
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
The box looks good :)
If you have the space to spare I would consider double baffling it just to be more solid, but that enclosure would work just fine imo.
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
it sounds soo nice.. im impressed with the output of them. but.. i emailed PWK for a design, so ill use this box till then.. ill get pics up here in a lil bit..
got the pics
yay..
Kinetik hc600
in a 2009 ford flex
-DISKOLORED AUDIO-
  • Who's Online   0 Members, 0 Anonymous, 4879 Guests (See full list)
