troy Posted March 2, 2009 Report Posted March 2, 2009 i need an amplifier that will do 800 rms at 1 ohms. or 400 rms x2 at 2 ohms. i want a good quality amp but realy dont need to spend alot. around 150 would be great. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Graph1cz Posted March 2, 2009 Report Posted March 2, 2009 http://www.onlinecarstereo.com/CarAudio/Pr...ProductID=19346 just go easy on the gain =] Quote
troy Posted March 2, 2009 Author Report Posted March 2, 2009 already had that amp it sucked^^^^ got realy hot. almost burned to the touch. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Graph1cz Posted March 2, 2009 Report Posted March 2, 2009 (edited) already had that amp it sucked^^^^ got realy hot. almost burned to the touch. i ran that amp for 3 months straight on over 14.4v and it ran fine. come to think about it i ran it before i did anything to my electrical before i totalled my truck. Edited March 2, 2009 by Graph1cz Quote
troy Posted March 2, 2009 Author Report Posted March 2, 2009 did you drop it down to 1 ohm Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Graph1cz Posted March 2, 2009 Report Posted March 2, 2009 did you drop it down to 1 ohm was actually running 2 12" kicker cvrs d4 ohm down to 1 ohm Quote
*1LOWSUV* Posted March 2, 2009 Report Posted March 2, 2009 (edited) Probably better if this was moved down to "Want To Buy" section...lots of Amps to be had around here. Let me know if your looking to buy and I'll move it or if your just looking for suggestions. : Edited March 2, 2009 by *1LOWSUV* Quote [email protected]
troy Posted March 2, 2009 Author Report Posted March 2, 2009 was actually running 2 12" kicker cvrs d4 ohm down to 1 ohm same exact system im trying to put on it. just got my other set today. in my last setup i had them on a kicker 750 but i just cant affor that right now. so you say its a pretty good amp? Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
troy Posted March 2, 2009 Author Report Posted March 2, 2009 Probably better if this was moved down to "Want To Buy" section...lots of Amps to be had around here. Let me know if you want it moved or if your just looking for suggestions. : im just looking for suggestions im buying the amp new. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Graph1cz Posted March 2, 2009 Report Posted March 2, 2009 (edited) same exact system im trying to put on it. just got my other set today. in my last setup i had them on a kicker 750 but i just cant affor that right now. so you say its a pretty good amp? i know other users on here that use it also with no problem. Just make sure you set the gain properly by ear or dmm. i had them in a 99 tacoma ext cab in a sealed box. banged pretty loud. i believe ptcary uses that amp. or the 1500 Edited March 2, 2009 by Graph1cz Quote
