Need Amp
troy
i need an amplifier that will do 800 rms at 1 ohms. or 400 rms x2 at 2 ohms. i want a good quality amp but realy dont need to spend alot. around 150 would be great.
retarded build on the way.....
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
fosgate hu/mids and highs
already had that amp it sucked^^^^ got realy hot. almost burned to the touch.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
i ran that amp for 3 months straight on over 14.4v and it ran fine.
come to think about it i ran it before i did anything to my electrical before i totalled my truck.
Edited by Graph1cz
was actually running 2 12" kicker cvrs d4 ohm down to 1 ohm
same exact system im trying to put on it.
just got my other set today. in my last setup i had them on a kicker 750 but i just cant affor that right now. so you say its a pretty good amp?
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
Probably better if this was moved down to "Want To Buy" section...lots of Amps to be had around here. Let me know if you want it moved or if your just looking for suggestions. :8)
im just looking for suggestions im buying the amp new.
2000 bagged s10
2 hdc3 15s
aq2200
aq4x90
stinger/knu wire
optima batteries
220 amp alt
i know other users on here that use it also with no problem. Just make sure you set the gain properly by ear or dmm. i had them in a 99 tacoma ext cab in a sealed box. banged pretty loud.
i believe ptcary uses that amp. or the 1500
Edited by Graph1cz
  • Who's Online   1 Member, 0 Anonymous, 1245 Guests (See full list)
