Hey guys,
The Saturn got a wiring and battery upgrade to bring it's electrical up to a more respectable level :) ...Enjoy
(this upgrade was a good while ago but just thought I'd share)
Pair of D3100's and a solid copper bar (.25" x 1.25") for busbars...
Posted Image
Posted Image
Engine bay before upgrade...blah..
Posted Image
Heating up the copper for bending..
Posted Image
Horizontal bandsaw cutting the copper down..
Posted Image
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
Posted Image
Posted Image
Drilled and tapped..
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Sides of frame prepped for wiring..
Posted Image
Some power wire..
Posted Image
Had to take out the spare tire tie-down for batt's in the spare tire wheel well..
Posted Image
Starting the power wire runs and fusing upfront..
Posted Image
Team Tupperware
Posted Image
Posted Image
Flying saturn!..
Posted Image
Posted Image
Posted Image
(it looks like theyre just sagging and hanging, but theyre more secure now)
Posted Image
Made it to the trunk..
Posted Image
Ground runs' turn..
Posted Image
Hole through the front, passenger side wheel well..
Posted Image
Finishing the busbars..
Posted Image
Posted Image
Posted Image
Ground runs starting..
Posted Image
Posted Image
Posted Image
Team Tupperware
Posted Image
Ground runs made it to the trunk..
Posted Image
Getting the speaker wire ready (yes, that's 4-gauge)
Posted Image
Mounting terminal..
Posted Image
Sizing up mounting for the amp..
Posted Image
For the inside of the enclosure..(8-gauge)
Posted Image
Posted Image
Posted Image
Posted Image
Posted Image
Team Tupperware
Got the amp's plate mounted and attaching anchors to mount the amp..
Posted Image
Trim panel back on...goes right over the 4-runs of 1/0 gauge :D
Posted Image
Posted Image
Has plenty of clearance..
Posted Image
Mounting bracket I made to hold the batteries down..
Posted Image
Posted Image
Piece of angle iron bolted in front of the batteries...
Posted Image
Bolts for the busbars, have to cut them down..
Posted Image
Cutting them down..
Posted Image
Piece of allthread for the hold-down bracket..
Posted Image
Posted Image
(more later on about the bracket)
ground runs attached to their busbar..
Posted Image
Team Tupperware
Prepping the rear fuse holders for the power runs..
Posted Image
Fuse holders cases mounted..
Posted Image
Posted Image
Power runs attached to their busbar..
Posted Image
Posted Image
Posted Image
(upfront in the engine bay..)
Bent the ground runs' ring terminals for a better fit on busbar..
Posted Image
Upfront finished! :D
Posted Image
Posted Image
Needs more wires :D
Posted Image
(Back to the mounting bracket)
Super glued the nut on one end to keep it from spinning..
Posted Image
Caulk on the washer and nut to keep it sealed up..
Posted Image
Posted Image
Team Tupperware
Prepping the fuses and distro I need for the amp..
Posted Image
Fuses mounted (ofcourse I run out of blue kolossus...so I have to make due with silver, ugh)
Posted Image
Posted Image
Power runs for amp and theground run connected and done
Posted Image
Posted Image
Bracket tightened down and holds them FIRM
Posted Image
The busbars were a bit higher than I was expecting so I need to make a spacer for the enclosure to clear them and the wires..
Posted Image
Posted Image
Posted Image
Posted Image
Bedlining them so they dont look tacky..
Posted Image
Posted Image
Team Tupperware
Bedlining done..
Posted Image
Sizing them up...
Posted Image
Mounted..
Posted Image
The 18 inspecting the upgrade...it seemed very pleased, but really just wanted to get back in the freakin trunk..
Posted Image
Posted Image
Posted Image
Team Tupperware
Wiring up the sub..
Posted Image
Posted Image
Port-wall mounting and fastened down..
Posted Image
Enclosure in and amp mounted and wired :D
Posted Image
Posted Image
Heated up and bent a screwdriver to adjust the amp without pulling it..
Posted Image
Team Tupperware
I get everything in and go take a test drive and hear something rolling around and notice my phone's gone...MY FREAKING PHONE WAS INSIDE THE ENCLOSURE...lol, but I was kind of ticked. But I just pulled the port wall and got it..
Posted Image
FINISHED :)
Posted Image
Posted Image
Posted Image
So far it's proven extremely solid :D Im happy with it
Team Tupperware
