This enclosure was for a member of another forum...it's specs come to 4.11 cubes net, 70 sq inches of port area, and tuned to 32.5Hz
Getting started, most of the panels cut..
Back going on the bottom panel..
A side going on..
Angled piece cut for the port..
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
A quick mock-up...
Port on..
Team Tupperware
DSCN2564.jpg'
Baffle cutouts (it'll be double-baffled)..
Team Tupperware
Last piece cut for the port..
Slightly rounded over/knocked down the back edge of the port..
Team Tupperware
Top going on..
A view inside..
Team Tupperware
Alright, all finished up :)
Terminal holes cut..
Look at the inside again, for fun..
And the carpeting begins..
Team Tupperware
Randomness view inside, again..
Face done and ish cut out..
Team Tupperware
One side done..
Other side..
All finished up..
Chyea..
Team Tupperware
And prewired and terminals in...
Done :)
Team Tupperware
Badass box man... Great job..
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
