Electricaly there is no problem if they are the same voice coil configuration.
but for sub performance. You wont be able to have the box perfect because different subs have different needs. it may not sound good at all because they also respond to frequecies differently. and if they are in the same chamber and one sub has more force than the other it could interfere with the other sub, and damage it. there are other reason too, just not poppin in my head right now. but the short answer is dont mismatch subs.
Sounds bad. I think I would even probably want to avoid the same speaker in two different conditions? one new, one used then.
a used and new of the same sub should be fine.
