Need Help Dsigning A Box
i have 4 15 kicker cvxs in a box that was suposed tobe a wall but was about a half an inch too tall so i was forced to have to lay it down so the subs and port face up and it sounds nice but i know it could sound way better
does anyone have any ideas on a box i can build so i can get a lot of air moving threw my car so i can do a hair trick
and your max dimensions are
R.I.P!
(Nov-29-2009)
92 explorer
current build
my bad i got a 2003 yukon denali xl i have the third row out im not quite for sure of the deminsions of the top of my head but i dot car how big the box is i just want to have enough air moving in my car to be able to do a hair trick
If you have a friend that has a termlab meter I guess you could check. But just to say I can't because I'm not going to lie to you.
J&T DESIGNS
M5
4 Audioque 15's copper coils dropping Audiopipe, and picking up DB DRIVE OKUR
Powermasters
XS POWER
Dropping MaxxSonics
Pioneer
