Crump Posted March 18, 2009 Report Posted March 18, 2009 His Ground Wire in the trunk, gets really hot when he uses it for more than 15 minutes. He used a self tapping screw and it held ok, but he thought it might come out. He put Electrical tape on the ring terminal to keep it down. Is it the tape? or a bad ground? Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
15VmaxXL Posted March 18, 2009 Report Posted March 18, 2009 Did he use the same size power wire as his ground? make sure when he grounded his wire he didnt hit something on the other side. Would be a dee dee dee move. sold everything
Crump Posted March 18, 2009 Author Report Posted March 18, 2009 Did he use the same size power wire as his ground? make sure when he grounded his wire he didnt hit something on the other side. Would be a dee dee dee move. yes both 0 guage, and i looked at where the screw went its clean. Team gg Team doa Installs I have doneMy 2010 Rebuild 144 db so far....2 DC xl 10s Firing into cabin on a RF 25002 12" AQ HD's powered by a Saz 2k + Lots o Mids+Highs
Guest Posted March 18, 2009 Report Posted March 18, 2009 try using a bolt and washer instead of a screw, could be a poor connection.
Guest KyleCannon Posted March 18, 2009 Report Posted March 18, 2009 Do above and check the resistance of the wire with a multimeter. try to hit a clean grounding point near the terminal connector and at the end of the wire.
