Guest Posted March 21, 2009 Report Posted March 21, 2009 I have my 4 channel Rockford 200.4, and i had this idea. will it work if i bridge the 4 channels to 2, then put the 2 channels to a single 4 ohm coil subwoofer. i will have the gains matched perfectly, or as close to perfect as i can get.
troy Posted March 21, 2009 Report Posted March 21, 2009 do you mean bridge it then run both channels to the sub? if so then no retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Got_Bass89 Posted March 21, 2009 Report Posted March 21, 2009 Interesting... Good Luck Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Guest Posted March 21, 2009 Report Posted March 21, 2009 do you mean bridge it then run both channels to the sub? if so then no why not?
troy Posted March 21, 2009 Report Posted March 21, 2009 it just doesnt work like that. thats a very quick way to ruin an amp id incorrect wiring. its meat to be sent to two separate sources. retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
Guest Posted March 21, 2009 Report Posted March 21, 2009 it just doesnt work like that. thats a very quick way to ruin an amp id incorrect wiring. its meat to be sent to two separate sources. really? wow...so running + from both channels (bridged channels) to + on sub and same with negative wont work.
troy Posted March 21, 2009 Report Posted March 21, 2009 yea it probbably will work but not very long until something fries out. it kinda like those hood rich systems where eeryone has their stuff "bridged" retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
