Neo_frog Posted March 25, 2009 Report Share Posted March 25, 2009 So over the course of the years I've picked up a bit on how the whole suspension system works in my car and I've done tie rods, control arms, hub bearings, among some other little things on my own...but I don't know about other types of setups. Now I have a problem. Every system I put in this little car drops me about three inches. It takes it well and I haven't had any problems yet. I just put new springs, struts/mounts, sway bar bushings and a few other things for my trip to Florida, but this next system is going to be heavy. VERY heavy. I'm quite sure with all the batteries and subs, it's just not going to handle it. What do I do now? Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
Neo_frog Posted March 25, 2009 Author Report Share Posted March 25, 2009 Basically, does anyone suggest performance suspension, bags, or something else? I'm really clueless about this one. Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
BURRITO Posted March 25, 2009 Report Share Posted March 25, 2009 you got me on this one! maybe some HD air shocks? Quote Barretto MotorsportsTeam RFCTeam CHMTeam SMD "Blow Sand"Live Your Life Without Boundaries... http://www.jeffbarretto.acnrep.com/d_oppor...A=US_EN&BW= Link to comment Share on other sites More sharing options...
Neo_frog Posted March 25, 2009 Author Report Share Posted March 25, 2009 you got me on this one! maybe some HD air shocks? Hmm. Thanks man, I'll look into them. I'm not too worried about my chassis, but since it's gonna be a daily driver, I don't want my suspension to blow out from excessive weight Quote Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/ Link to comment Share on other sites More sharing options...
badcayne Posted April 8, 2009 Report Share Posted April 8, 2009 you can probably upgrade your coils to some heavy duty ones, or even go with a simple bag setup. it would be kinda hard to blow bags out due to weight,they handle around 2000lbs each bag. Quote Link to comment Share on other sites More sharing options...
wierdguy75 Posted April 13, 2009 Report Share Posted April 13, 2009 you can probably upgrade your coils to some heavy duty ones, or even go with a simple bag setup. it would be kinda hard to blow bags out due to weight,they handle around 2000lbs each bag. +1 I would go with bags, like meade did in chickens caddy Quote Link to comment Share on other sites More sharing options...
JayPhoenix Posted April 28, 2009 Report Share Posted April 28, 2009 Definitly put some helper bags in to ease the weight off the suspension. Works wonders for keeping the look level and depending on the application is relatively easy to throw in. Quote "The Only Way IS, All The Way!" 1997 F150 - 130AMP alternator, Optima Red Top, Streetwires 0/-1G Power and Ground, 8Farad Soundstream Capacitor, Kenwood CD/Mp3 Player, Kenwood 6x8's Front and Rear 2 RE Audio SX 12" Woofers w/3.75ft3 tuned at 33Hz, US Amps XT-4000D Amp 2000 F150 - 130Amp Alternator, Kenwood CD/Mp3 Player, JBL 6.5" Components Front, JBL 6x9 Rear, Rockford 10" P1 Link to comment Share on other sites More sharing options...
