even though your amp is putting out -/+ 30v, for reliable a Bi Polar cap rated more like 200 - 600 volts would be better ( this only has the ability to store that high of voltage with that voltage input, you wont get 200- 600v going to your sub)
A little cap like that probably wont last long. Another thing you have to look at is the resistance of the cap, it might be 0.5 ohm, might be 10 ohms, so you need to put that in to your amp power consideration
Edited by Forevrbumpn
that will take up alot of my time trying to find the right part that can be used for what i need w/o having other side effects.
Degrade the sound quality?? It's sub bass...it's a pretty damn easy signal, you could carry it over a coat hanger.
im starting to lean towards those in-line rca connectors you showed me creyc.
