Is one fi bl 15" 1 ohm stable on a mono block amp? I plan on using this amp but would there be a cheaper choice that is just as good? AMP
Also, if you design enclosures, could you please PM me?
Thanks.
that does not make sense.
DC.jpgDC POWER
well then lets help him make it make sense...
i think you mean to ask if the amp is 1 ohm stable and if the subwoofer can handle the power said amp puts out at 1 ohm. im pretty sure those amps are 1 ohm stable. and yes the sub can handle that power with ease.
Thanks.
It's the amp that has to be stable at a given ohm load. Say you have a two ohm dvc sub, you can wire for a final load at the amp of one or four ohms. If the amp is stable at one ohm, then you can wire your sub to one ohm.
  • Who's Online   1 Member, 0 Anonymous, 623 Guests (See full list)
