Enclosure For 18 Btl
dsawyer09
hello all, i recently purchased a Fi 18 btl fully loaded dual 2ohm and was going to power it with an audioque 2200d amp. i was thinking about a box that is around 6 cubic feet tuned @ 33hz or whatever will fit in the space i have, though i would like to keep the tuning around 32-35hz. i need a good box design that will work the best for a daily driver/occoasional comp just to check the numbers. i was thinking having sub up and port forward, but im down for any suggestions
the space that i have to work with is
35 inches wide
30-32 inches deep
20-24 inces tall
pics of the space i have to work with:
6.6 cubes after displacement 92.5^2 of port tuned to 32hz
R.I.P!
(Nov-29-2009)
92 explorer
current build
wow, that looks tight and that was a fast reply. what are the measurements on that box?
  • Who's Online   0 Members, 0 Anonymous, 3805 Guests (See full list)
