In the RE calculator type this in the red in this order.
http://reaudio.com/speaker_box/LPort_Box_Calc.html
30
16
24
24
0.75
4
0
16" H x 30" W x 24" D
4.5cuft @ 32.79Hz without the sub - Fi BL 15"sub displacement is .18cuft = 4.32cuft @ 33.xx Hz with the sub .
Little bigger than listed but I think this size is acceptable and will bang hard .
As you can see 4" slot port x 26" long = length to width ratio of 6.5:1
58sq in port area , 13.43sq in per cuft .
Cut sheet ~
Bottom - 24"d x 30"w
Back - 14.5"h x 30"w
Left side - 14.5"h x 23.25"d ( port side , drivers side )
Right side - 14.5"h x 22.5"d
Front - 14.5"h x 25.25"w
Port- 14.5"h x 18.5"d
Top- 24"d x 30"w
Final ~ 4.32cuft @ 33Hz displaced , 58sq in port area
Sub inside cut diameter = 14.125" .
Edited by Joker
2000 Trans Am ws6 - 6spd / M9 / cam / full bolt-ons / semi full suspension / tune
1998 Integra - daily beater, [2] AB XFL-1244's / 4ft³@35Hz, 61in² / Saz-3500dv1 @.85Ω
30
16
24
24
0.75
4
0
Cut sheet ~
Top- 24"d x 30"w
so just cut the wood to that with mdf, and when it's together, those dimensions will give me around 33hz and around 4 cf3?
