yea a fuse after each POSITIVE Terminal..
BUT IV SEEN PPL RUN COPPER RAILS ACROSS THE TERMINALS WITH NO FUSE????
SAME WITH THE NEGITIVE SIDE???
how does that work??
Edited by SubSonic
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
ok thanks,
if i have 4 batts, i run a wire across all the POSITIVES,
A wire across the NEGITIVES,
and then ground each battery? right..
yup. u could either run wire or you could use copper buss bars instead, much cleaner IMO :D
2000 Eddie Bauer Expedition:
Alpine CDA 9883
2x 18" DC lvl 4 D2
10.7 cu ft box 33hz
knu 1/0 wire
amp: Kicker ZX2500.1
Kinetik
you don't have to fuse b/t each battery. Only if they are far apart. The whole point to fusing is to stop a short circuit from happening. So if you only have 6in of wire b/t the rear batteries, then your chances of a short circuit is slim. So I would just fuse b/t your positive run(s) from the front battery to the back and b/t the amps and batteries.
Bus bars are just as good if you get them large enough IIRC. Plus, they look a lot better.
  • Who's Online   0 Members, 0 Anonymous, 764 Guests (See full list)
