A&W ROOTBEER Posted April 1, 2009 Report Posted April 1, 2009 quick question..im shopping around for a 4 channel amp for my component speakers and each set is 3ohms so when wiring both sets to a amp whats the final ohm load i will end up with? for some reason i keep thinking it will be either 1 or 6?
uhoh_45 Posted April 1, 2009 Report Posted April 1, 2009 quick question..im shopping around for a 4 channel amp for my component speakers and each set is 3ohms so when wiring both sets to a amp whats the final ohm load i will end up with? for some reason i keep thinking it will be either 1 or 6? think of it this way you X 2 or divide 2 so if each speakers 3 ohms you can wire it to 1.5 or 6 ohms R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
