i'm back, 100 or 120 amp fuse? or bigger? or as long as it's at least 100 does it even matter?
if your going to be playing music in a daily driving scenerio, you should only pull about half of the amp's max draw. if you're using it for burps and tones, then it will pull more current.
i would say to match your amp's total fuse rating on the power wire or just a little under that. i choose to do a little less so that it will blow before the bad power can get to (and hurt) the amp.
as an example, on my old pioneer... it had (2) 30 amp fuses on the amplifier, but i used a single 40 amp fuse inline. i've never had any issues because the lower fuse will blow first in my case.
Edited by J00bles
8 DC Level 4 M2 15s2 DC Audio 5ks26^2 clamshell tuned to 30hz9 Kinetik 1400sMechman externally reg'd 340 S seriesin a 99 Jeep Cherokee :DClick to see J00bles' Youtube Channel
so i should do a 80 fuse for my 90 amp? or 60??
Edited by Bali
why does the knu kit come with 4 ring terminals but no spade terminals? also, no speaker wire either?
Which do you guys recommend for both to fit my setup, also does red and black matter which end i put on the wire?
It will work with a reducer.. Or trim... But no not gonna fit as it is...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
  • Who's Online   0 Members, 0 Anonymous, 3176 Guests (See full list)
