troy Posted April 10, 2009 Report Posted April 10, 2009 any quick and cheap mods to get more performance. Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
white4d96 Posted April 10, 2009 Report Posted April 10, 2009 I did a cone filter on my 3.1 and picked up a little power, sounds better too. I think you can find headers, cat-back etc for a GTP, they will all fit iirc. Or if ya wanna go for bigger, GTP swap =P I'm not sure if those engine's internals are different from yours; may be diff. compression or something. Either way, you want that GTP tranny and axles, and need the ECU and harness. get that together and its about 240hp and 260tq stock, and you can pulley it into even more power. Quote Too many projects, too little time...
troy Posted April 10, 2009 Author Report Posted April 10, 2009 the make full exhaust kits for my car. they also have headers and everything else. prolly will do that next Quote retarded build on the way..... 2000 bagged s10 2 hdc3 15s aq2200 aq4x90 stinger/knu wire optima batteries 220 amp alt fosgate hu/mids and highs
