Audioque A1200d Amp Clipping?
GUCCI_BASS09
running a audioque hdc3 15 & audioque1200d amp...0 guage kicker wire,,,kinetik1400 batt,,,,,,stock alt,,,,,,,now with audioque amps the bass knob has a clipping red light so i guess if your clipping it flashes red..now anyone that knows about this first is it accurate and how can i crank it up and not clip it,,,,,,,bigger amp,,,,upgrade alt.....thanks for the help
Im guessin you listen to alot of gucci?
Because most if not all his song's clip like hell lol.
Happen's on my friends aq2200D some song's.
2 SSA Xcon 18's
Sundown 2500D
Pioneer
4 Stinger SPV35 batts
SecondSkin Audio Damp Pro
Knukonceptz Flex[/size][/b]
alrite.
i run the same amp.
i have checked the clip light and it is pretty accurate to what an o-scope was telling me. so...
this is what i do. if you don't know what you're doing DO NOT DO THIS! THIS IS NOT THE CORRECT OR SAFE WAY TO DO THIS
i turn my gain all the way up and then adjust my signal with my bass knob. when i see any red at all i turn it down until the light goes away.
AGAIN I SAY THIS. IF YOU DONT HAVE A CLIPPED SIGNAL LIGHT DO NOT DO THIS.\
i only do this because i have checked mine with an o-scope and i know that when that light comes on it is giving it a dirty signal. check your setup before you do this.
alrite.
i run the same amp.
iight cool thats pretty much what i do now thanks
just know that clipping your signal will eventually make your subs so hot they will tear themselves apart.
i didn't really trust it until i used an o-scope and it is almost right on with the clip light. :)
now i realize how accurate it is (gives a dim light if barely clipped and really bright if it is straight dc signal)
i love audioque amps just because of that light on the bass boost knob. plus they put out rated power.
just be careful with it man.
also, how is your pre amp voltage? Maybe a line driver will help you...
Eclipse cd7000
Not smart to leave your gains wide open like that. If tha tbass knob goes bass or gets unplugged. Poof, Wide open gains = death to components.
true. like i said if you don't know what you are doing then don't do it.
also i have the bass boost turned all the way down on the amp so even if it does come unplugged the bass boost will be all the way down.
  • Who's Online   0 Members, 0 Anonymous, 778 Guests (See full list)
