i kno the standard
A.you can Z the frame (or notch) in the front by the firewall, and back down in front of the A arm mounts...
B.i could buy a pre made X-MEMBER that will layit out flat and narrow the track width (around 2k$)
C. start cutting and see what happends lol
im realy just wanting to find sum people that have delt with the X-MEBERS on a C series chevy 80's model ?
pics or any ideas would be nice, ill post pics and a build log soon!
she's a beast
thanks guys
*2013 NEW BUILD*
12- 18" Crossfire XS v2's B pillar 4th order wall
4- Crossfire 8K mono blocks
40+ pro audio mids tweeters and horns
3- Singer alternator 400a external regulated alts
tons of audiotechnix wire
24- XS Power D1400's
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
If I was going to spend the money on a new crossmember i would look at the p57 from www.suicidedoors.com. the porterbuilt front end is nice but a little more pricey and you can pick it up from kp compnents. I think fatman fabrications make one too. I have bagged 3 of these trucks, and I always z'd the frame, less money, you just have to notch the drivers a arm and a steering shaft support, i used a heim joint
  • 1 month later...
thanks iv heard of people sayn that you can chop it down... but i didnt rly wana go in blind and screw up my only extra X-member thanks, and yeah my dad has his own fab shop, and me and a few friends are fairly skilled thanks for the link mane
*2013 NEW BUILD*
-TEAM XS POWER-
-TEAM CROSSFIRE-
-TDH-
  • 4 weeks later...
just do a stock floor body drop and build a new frame from the engine mounts back that will fix the crossmember problem and drop you a couple more inches. If you have a fab shop and some skills you will only be out a few hundred dollars for the metal and a fuel cell.
2003 Ford F-150 Reg Cab layin body on 26's
2003 Tahoe 3/5 drop on 26's with a 408cid Supercharged engine.
2011 Camaro 2SS 2005 VW GTI Stage II ECU, CAI, 3" turbo back exhaust, FMIC, lowered 2" on some plastidipped 18's
2003 Hayabusa lowered, stretched, cams, nitrous and custom paint
