I have found a lot of higher end subs with big coils will smell a little bit the first time you get some heat in the coils, I think it's just excess glue/solvents/activator boiling off.
You don't want to do it too much though :P Clipping will cook them in a hurry.
There's a difference in the smells IMO (sorry OP! heh) between hot gluely coil and burny coil. To me glue smells kind of rich but when you're actually burning the enamel on the coil it smells acrid like burnt leaves. Fortunately I don't smell either of them too often...
10.x volts fo' life!
to answer the questions, yes there are distinct smells a subwoofer gives off
a smell of the glue/varnish burning off during break in
and the eerily similar, but much more harmful, burning copper smell, common to all electronics (i've smelled it on everything from amps to hu's to unfused power lines that shorted)
as long as your subs arent being clipped too badly or overpowered (which they arent on that amp afaik) you should be fine, and it's probably just the smell of the varnish, and should go away after like 10-20 hours of beating on them
Team DC
^^^ 2x
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Good shit guys. I've had pretty good luck with all the subs I've owned over the years. (DD, Kicker, RE, JL, Onyx, Fi) I blew one of my 15 L7s, first time I released the magic smoke. :lol: Was quite a shock to me.
Then the old Onyx LSX 18s, seen here:
I believe it's very close or the same as the RE HC. Originally had two, but went to one when I got my Impala. Put my Orion 2500d at 1 ohm on it and it died after a few weeks. Reconed it, lasted a few more weeks and died again. They'd take 1,200 all day and all night though. I miss those subs, they sounded amazing.
2001 Chevy Impala
Eclipse CD7200 mkii
Cactus Sounds 5kw
Sundown 100.4
(2) Fi BTL 18s (walled)
ID 6.5s (2 sets)
Iraggi 320 amp Alt
XS Power Batts
KnuKonceptz Wiring
MidwestSPL Scores:
152.0 Advanced 2
136.1 Extreme 3
  • Who's Online   0 Members, 0 Anonymous, 2367 Guests (See full list)
