i am planning to use 12 kicker cvr 12s in a wall in the truck i would like to wire em all down to 1 ohm or closest i can get how would i go about wiring all them? what ohm do i want to buy svc or dvc? also will be running off 1 amp most likely saz 2000
thanks mike
no you want dual 2 ohm if your doing 4 and dual 4 if your doing 2
Subs are like titties, They need to come in pairs because ones and threes are just wrong, and larger amounts will always draw a crowd, we all have our favorite sizes, but the bigger ones are more fun to watch move. :D
Words to live by.
R.I.P!
(Nov-29-2009)
92 explorer
current build
with 12 cvr's you could run something more in the 6000watt ballpark, 2000ish will barely get em moving
with dual 2's you can get a 1.33ohm load, probably best you'll get without going under 1...
you could get a .67ohm load if you use dual 4's....
cvr doesnt come in single voice coil afaik
i just like did this in my head figuring 3 banks of 4 subs...if you do like 4 banks of 2 subs it should still be the same i think, idk how you plan on wiring this or whatever
Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build
monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now)
Team DC
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewI...E:X:AAQ:US:1123
kicker comps my bad
i will be running 12 of either depends on which i go for in the end, would 2 smaller 1500 watt amps be more effective in doing this making it easier for me ti wire up? and you said .67 ohm load with all the subs wont it raise the ohm load up some? and even if it was under 1 ohm i think the saz 2000 would be safe at running it
http://www.audiosavings.com/products/PAIR-...894.r3a8bd.aspx
Edited by mxmike800
