t-roy Posted April 14, 2009 Report Posted April 14, 2009 anyone run this fan? can i run it just like my old one, i have it grounded on the amp and then the other one on the remote wire so it comes on evertime i'm bumpin or does this fan pull to many amps ? or would that be ok? http://www.darvex.com/TF5/XScorpion+Small+Crossflow+Fan.html
t-roy Posted April 14, 2009 Author Report Posted April 14, 2009 needing to know because i'm in the middle of my Darvex order and just thought i'd like to have one but it don't ssy how much power it draws. need help fast i should of thought of this a head of time
qu1cks1lver56 Posted April 14, 2009 Report Posted April 14, 2009 id put it on a relay off of the remote wire instead of just running it off the remote wire. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
t-roy Posted April 14, 2009 Author Report Posted April 14, 2009 id put it on a relay off of the remote wire instead of just running it off the remote wire. so i'd fuse it or what type of relay would i use?never done any thing like that
qu1cks1lver56 Posted April 14, 2009 Report Posted April 14, 2009 just a normal relay, +12v input, ground input, remote input, +12v output. can find them at an auto parts store or a stereo shop. i use mine off the dblock for my amps, that way its fused too. First Gen Xterra: Always changing DNX 690HD RF 360.3RF T3002RF T4004RF T10001bdSilver Flute 6.5"s Tang Band 1" TweetersSundown X18 in 7cubes net tuned to 32hz Trust me .25 Blows your Load.
raytard Posted April 14, 2009 Report Posted April 14, 2009 x2 on relay off remote wire, remote wont power it i saw one used in a false floor to give some ventilation, and it seemed to work pretty well, but the draw was a few amps, not the .5 most decks can handle. (not sure if it was that one, but it was a similar style and size) Build: http://www.stevemeadedesigns.com/board/ind...hl=avalon+build monster/rockford/kicker/stinger cables, pioneer source, jbl highs/amps, kinetik/shuriken batts, iraggi alt, dei security, dc subs(atleast for now) Team DC
fritosaregood Posted April 14, 2009 Report Posted April 14, 2009 x2 for a relay. i run 4 fans, not the ones your looking at though, off my relay. i have my ignition wire hooked to it instead of the remote wire edit: x3 seller feedback: http://www.stevemeadedesigns.com/board/ind...showtopic=61719 http://www.stevemeadedesigns.com/board/ind...showtopic=68281 build log: http://www.stevemeadedesigns.com/board/index.php?showtopic=44800 Gf's build: http://www.stevemeadedesigns.com/board/topic/54346-kickergirls-camaro-new-box-pg-5/#entry753970
