Wiring Subs Down With Sealed Chambers?
JLAudio_15
If i have 3 subs all in different chambers and want to wire them down to the appropiate ohm which is .677 ohms or something lik that how would i do it if my box is sealed?????would i drill little holes though the chamber , run the wire through, and then seal the hole????
or could i just get the little black and red terminal things and wire the subs down that way????
yes u can just take a drill bit and make a hole just big enought to run wire thru it...then go back and seal around it with silicone. thats what i did....
Shit do like steve did with the stud terminals then when u run the studs threw b 4 u put the washer and bolt on throw a bead on liquid nails around bolt the stud together and wa-lah.
  • Who's Online   0 Members, 0 Anonymous, 405 Guests (See full list)
