Gotz1lung Posted April 15, 2009 Report Posted April 15, 2009 I have had a 300amp ohio gen. alt given to me. The problem: Its a 4wire and my trucks system is a 1 wire.. is there a way to convert the 4 to a 1?? 93 Chevy Silverado Crossfire,Dayton Soon to have 6 Lvl4 15s DC Audio Dealer and Team Member
Soulman07 Posted April 15, 2009 Report Posted April 15, 2009 I have had a 300amp ohio gen. alt given to me. The problem: Its a 4wire and my trucks system is a 1 wire.. is there a way to convert the 4 to a 1?? search for conversion plugs, I know there's one that exists for cs130 to 144 and so forth. There's resistors inside of the wiring harness. alternator model I'll help search 1993 Chevrolet SWB Pickup Viper 791XV Primer Stage 5/8 Static Drop Kinetik HC1800 Big 3 Knu Flex 0 Team Tex Flex
Gotz1lung Posted April 15, 2009 Author Report Posted April 15, 2009 search for conversion plugs, I know there's one that exists for cs130 to 144 and so forth. There's resistors inside of the wiring harness. alternator model I'll help search The only model numbers are the stock case imprints. The history on it as told to me was, from a 02 Escalade, sent to Oh. Gen and built.A steady output of 287-293 amps are on the build sticker. I know nothing about the damn things so if you can point me in the direction of finding you a correct number i will gladly look at it when i get home tonight. 93 Chevy Silverado Crossfire,Dayton Soon to have 6 Lvl4 15s DC Audio Dealer and Team Member
Guest KyleCannon Posted April 17, 2009 Report Posted April 17, 2009 If you still don't have an answer, call Robbie @ DCPower 888.441.0144 He will tell ya what you need and most likely be able to get it for you. (If it's possible)
