Rewiring Speakers
I think I have a short in my front speakers or something, I keep killing doors. I am planning on rewiring them, but would really like to retain the factory HU connector...is it possible for me to do this? Also, how do I run the wire through the dash? I know it will be a PITA but is there any way to make it easier?
Too many projects, too little time...
Anyone? Maybe a way to depin the factory wire, then transfer the pin to the new wire?
Also, what gauge should I use?
you will have to remove your dash most likely, but all you need to do is cut the tip off the factory harness and solder/heatshrink your own wires on there, then run them back the same way they were (unless you can do it better.... they do things fast at the factory, might be a better route to run the wires.)
  • Who's Online   0 Members, 0 Anonymous, 1033 Guests (See full list)
