i can squeeze between 2.5-2.85 after displacement of the sub for each sub would it be best if i ran them in a shared box if this would work what should my tuning of the port be?
Edited by slamnkingcab
why is it that only a select few respond to my threads seems like unless your runnin fi,re,aa,dd, or some other expensive stuff no one responds thank you kranny for your help bro i was able to purchase my 3rd sub i jus need help with a box now
go sealed, its too small
it was already said, you didnt read it
9 would be a minimum, plus port, 15ish is better
if you have maybe 8, just build a spec sealed box, ported wont fit
Team DC
steve's is smaller than spec because he is running over double the RMS to them
you are WAY underpowering yours, and should make as big a box as possible, since you have to decide besides building an ideal sealed box and a bad ported one, just do the one you can do well and make it look good.
Team DC
