You could go all out and learn how to fiberglass and make new door panels.
if you dont wanna do that thought the best way it to get rid of the plastic housing, and make a adapter out of 1/2" mdf. Ive even gone as small as 1/4" mdf to get some 6x9s in a 5.25 spot.(with some metal cutting)
  • 3 weeks later...
FINALLY SOME PICS
The Quarts are not as screwed as I thought, I put some foam tape between the basket and the housings seen above and it sounds a little better...still looking to upgrade to 6.5's eventually though.
EDIT: that perforated part of the plastic fits a 5.25" speaker PERFECTLY, and it looks like there's plenty of room around it.
Edited by ktownsdriftking
Too many projects, too little time...
I got some glass skills, not much though. Ive been wanting to do doors or door pods. If i do my whole door, ill probably do 2 part foam. Ive used it a bit before, shit is kinda cool. I see alot of people that do door panels or just pods, but it never shows how its attached to the door if its the whole panel or how the pod is attached to the panel. I wanna put 2 sets of 7" daytons and some tweeters in my front doors. Already kinda know where the tweets are going seeing as i already got type s comps up front and cut a hole and flush mounted my tweeters in the door panels.
you might have to keep an eye on me then. after i get my box im workin on now done, ill be workin on new door panels to put 2 7"daytons in each. But how i do it is i go and get door panels from a salvage place and strip id down to just plastic and start from there
lemme know when that starts, ill be tuned into that one. lemme know how you like the daytons when you do it.
ive got a single dayton in both front doors now. each in a small sealed box filled with acousta stuf and they sound great
