moh.vze.com Posted April 18, 2009 Report Posted April 18, 2009 There was a big improvement in my electrical. I haven't had time to take voltage readings at the amp yet but I took some readings at the battery. Old without yellow top + big 3: drops down to 11.4 volts (on white girl slowed unclipped with audacity). New with yellow top + big 3: drops down to only 12.5 Volts after 30 minute of playing songs (tested with white girl in the end). With engine on it reads 14.5 volts. Great stuff! I don't have any cameras to take pictures I think it would have been a lot better readings if I didn't make my ghetto 0 gauge extension for the stock wiring. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Guest KyleCannon Posted April 19, 2009 Report Posted April 19, 2009 Great to hear! Funny on my stock alt and after I did only the positive run this is what i got: Hard to read but thats 15.01 volts on a stock alt
moh.vze.com Posted April 19, 2009 Author Report Posted April 19, 2009 Great to hear!Funny on my stock alt and after I did only the positive run this is what i got: Hard to read but thats 15.01 volts on a stock alt WTF! How can this be? DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
Guest KyleCannon Posted April 19, 2009 Report Posted April 19, 2009 Well, I wasn't beating on it or anything but thats right after i turned the car on after the upgrade took place. By the time i got home the car realized what happened and it throttled back down haha. But it goes to show you how much better things work with a better electrical system.
machado287 Posted April 19, 2009 Report Posted April 19, 2009 this is a newbe ? but what is a big 3 ? 02g power wire sundown saz 3500 digital desing 95F selenium mechman alt. 250 amp
Got_Bass89 Posted April 20, 2009 Report Posted April 20, 2009 Well, I wasn't beating on it or anything but thats right after i turned the car on after the upgrade took place. By the time i got home the car realized what happened and it throttled back down haha. But it goes to show you how much better things work with a better electrical system. Display is off by a bit... Don't get too excited.. Check with actually dmm Passport Build Here Alarm: Prestige APS997A 2-Way/Remote Start HeadUnit: Pioneer DEH-P6000UB Front Battery: Yellowtop Optima D34/78 Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH Subs: 2x DC Lv4XL 18's Amps: 2x Sundown Saz1500's Strapped Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube) Pillars: AudioBahn AS31Q Front Doors: Clif Designs TX40.5 Back Doors: Clif Designs CD50.4C Rear Speakers: Clif Designs TX46.5 Front/Rear Amp: Kicker ZX350.4 Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4) Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Guest KyleCannon Posted April 21, 2009 Report Posted April 21, 2009 That was months ago bro. As I remember it was very accurate actually.
moh.vze.com Posted April 21, 2009 Author Report Posted April 21, 2009 Meh. I'm still a bit surprise that my voltage drops to 12.5 volts with certain songs. I was hoping it would stay above 13 volts. I have an extra 4-5ft of ground wire left. Are there any places I can add another ground for improvement? Is it worth buying two more ring terminals to use it? Also, I've read on a lot of forums where people's positive alternator had a rubber thing under a plastic covering. Mine didn't, but was that rubber thing for? My 0 gauge ring terminal is pretty close to the engine pipe of my car. Should I be worried? How hot does it usually get? I don't want my soldered ring terminals to heat up. DC Audio - Singer Alternators - Knukonceptz - XS Power - Hybrid Audio - Rockford Fosgate - Second Skin Audio - SMD - Sundown Audio - Elemental Designs
