Bali Posted April 21, 2009 Report Posted April 21, 2009 If this sub is a fi bl, i wire it like this to my mono amp for a 1 ohm load correct? Also should i use a 12 gauge speaker wire for a fi bl or bigger? (1200w 15")
Darksideofsound Posted April 21, 2009 Report Posted April 21, 2009 If this sub is a fi bl, i wire it like this to my mono amp for a 1 ohm load correct? Also should i use a 12 gauge speaker wire for a fi bl or bigger? (1200w 15") you need to connect a wire from the negative coil to the other negative of the other coil.....then run a wire from either negative coil to your amp, same applies to the positive side...12 guage is a good size.
Bali Posted April 24, 2009 Author Report Posted April 24, 2009 can the two wires touch in the same coil?
ryde2idie Posted April 24, 2009 Report Posted April 24, 2009 can the two wires touch in the same coil? what you mean Quote
