need way more info. what car, how much space do you have, do you want SQ or SPL, whats your electrical situation? theres alot of factors. we cant just tell you to get X sub over Y sub
^x2...very situation/install dependent
Team Tupperware
<First dual-alternator 'real' Saturn (pre-2002) on the planet>
(3) 15" Fi SP4's fed by (2) M3a's strapped @ .667
12.75 cubes net @ 25Hz with 200 sq inches of port area (lowz...?)
Stock alt position (custom bracket) 225 amp Mechman
Roof = steel and fiberglass (u mad?)
(2) XS Power D3100's, (2) rhino batts, No battery upfront (for now, smh)
4 power+ 4 ground runs of 1/0-gauge to rear
"If its been done before...you're doing it wrong" : )
"stfu about scores and float $hit..."
i have a 04 dodge stratus, stock electrical but need to know what i need so i can get it and honestly i want something thats gonna pound but sound clean at the same time thanks.
Granted you have the electrical and experience to back the install up.
x2, experience and knowledge is a VERY important part in installing a high powered system.
you would need to spend a hefty amount on electrical upgrades alone if you want to support a +2000w speaker. if you want a clean sound, the mayhem would be the way to go (vs the btl), but if you want cleaner sound, you can go with the AA Havoc or the Fi Q.
Edited by Krannyman92
so since i have stock electrical would it be smarter to go with a fi bl or aa havoc also would an 18 be good for my trunk space?
for SQ, i would go with a Havoc or a Q, for SPL, go with a BL. those should be fine on your electrical system if you add a secondary battery.
an 18 might not fit. measure your trunk dimensions for a rough estimate on how big of a box you can fit.
the trunk space is 16 cubic feet also would two 15s be better?
  • Who's Online   0 Members, 0 Anonymous, 1639 Guests (See full list)
