Braden062005 Posted February 26, 2007 Report Posted February 26, 2007 (edited) I'm building a box (my second one) the first one i build i'm ashamed about so im not going to talk about it. Anyhow, i am building a new box for 2 RF P215's i looked at the manual to get a understanding of what i would want, but they only show 1 sub boxed, which i need 2... i want to just double it, then section it off in the middle, do you think that would work good or should i go with no section? I'm also porting the box with two 4x9.4 inch port, should i just go with PVC? And lastly, would home depot cut it to make it very exact? Edited February 26, 2007 by Braden062005 Quote 2 RF P215's Rockford 1 farad digital cap RF X6.c Amp Alpine head unit JBL GTO component door speakers and two way rear deck speakers
SPLGEO Posted February 26, 2007 Report Posted February 26, 2007 It would be louder in the same chamber, regular PVC pipe isn't that great, look into areo or pression ports, a sllot port would be easyer, I can draw you up a design, PM me if you insteraded Quote 1995 Geo Prism . FI BTL 12 P chamfer, 3rdmagnet HIXMAX COIL 1/0 big 3 HIFONICS COLOSSUS 1.7 cubs tuned to 60hz in the works 2xTruck battery 1125 cca.
Braden062005 Posted February 26, 2007 Author Report Posted February 26, 2007 It would be louder in the same chamber, regular PVC pipe isn't that great, look into areo or pression ports, a sllot port would be easyer, I can draw you up a design, PM me if you insteraded where can i get them at? Quote 2 RF P215's Rockford 1 farad digital cap RF X6.c Amp Alpine head unit JBL GTO component door speakers and two way rear deck speakers
sean 371 Posted February 26, 2007 Report Posted February 26, 2007 partsexpress.com http://www.psp-inc.com/ Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Braden062005 Posted February 28, 2007 Author Report Posted February 28, 2007 Thanks for the site. I got all of my wood cut, finally decided on a design that will take up essentially my whole trunk, should be nice and sound great, i'm using 3/4 MDF and i bought carpet to put around it. I have a question, what kind of resin can be used to put in the box, also what else can i do to make the box better? The dimensions are 12" H, 35" L, 28" W then i figured i should run a 4x9.4 port. Quote 2 RF P215's Rockford 1 farad digital cap RF X6.c Amp Alpine head unit JBL GTO component door speakers and two way rear deck speakers
sean 371 Posted February 28, 2007 Report Posted February 28, 2007 Fiberglass resin. Brace the box unless your designs has bracing already included in it (ie the port is in the center). You can do a double baffle if you want. You could put 45 all the angles on the inside of the box. It's up to you how in depth you want to go. With P2's, you should be okay with just a standard box. Use good wood glue and brad nails if you can. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Braden062005 Posted February 28, 2007 Author Report Posted February 28, 2007 what would be the advantages to keeping the box sealed? any? do you think i have enough to run ports? 1 or 2? Quote 2 RF P215's Rockford 1 farad digital cap RF X6.c Amp Alpine head unit JBL GTO component door speakers and two way rear deck speakers
sean 371 Posted February 28, 2007 Report Posted February 28, 2007 By standard I meant without bracing/double baffle. By all means port it. The only advantage to sealed is it supposedly gives a "punchier" feeling. Ported boxes are the way to go if you have the space, IMO. Either one or two ports would work. Quote A couple links to some box builds: Tahoe Box 1, Tahoe Box 2, Nissan Titan, VW GTI, Mini-Bump, Hummer H2, Ford F-150 My own car builds (current setup --- under construction): Overall Thread, Kickpods, Dash, Back Doors Subwoofer Wall
Braden062005 Posted March 2, 2007 Author Report Posted March 2, 2007 I'm done with the box, it really hits hard, not to mention the fact i had to hit it hard to get it in, its so tight... but i'm happy with it. I'll post some video's tomorrow to show you guys, and let me know what you think. Quote 2 RF P215's Rockford 1 farad digital cap RF X6.c Amp Alpine head unit JBL GTO component door speakers and two way rear deck speakers
Braden062005 Posted March 2, 2007 Author Report Posted March 2, 2007 (edited) heres a couple images of the box. notice the footprints lol on the second one from kicking it to get it in. http://i161.photobucket.com/albums/t229/Br...05/100_0711.jpg http://i161.photobucket.com/albums/t229/Br...05/100_0709.jpg http://i161.photobucket.com/albums/t229/Br...05/100_0707.jpg Edited March 3, 2007 by Braden062005 Quote 2 RF P215's Rockford 1 farad digital cap RF X6.c Amp Alpine head unit JBL GTO component door speakers and two way rear deck speakers
