I accidentally bought 2, only needed one, I' am not tripping about the loss to sell this one for cheaper than retail, because I ended up getting 2 sets of RCA's that I DID want for free.
I will even throw in the Parts Express tuning screw driver.. lol
Anyways, yeah brand spankin new, PM me, or ask questions here
This is EXCELLENT to use on older subs, or subs that are thoroughly broken in, or lost on T/S parameters, and really want to get a box design right
Most subs you see with there specs are NOT broken in specs, usually right out the box, picked randomly and tested. A broken in subwoofer does have a lower Fs than brand new, and sometimes other things will change like Vas, and Qts, not alot, but slightly
I'am asking $100 shipped
or $80 picked up locally- I rather sell locally, but I guess I still have the packaging and all that stuff, so shipping is possible
Its really simple actually, now I use it all the time. You just have to know how to switch your speaker, and microphone selections around first off, took me a day or so to learn
has alligator clips you hook up to your terminals, testing should be done in Parallel, for the higher ohm. I always test my speakers per terminal first, then final results in parallel. If you test your sub per terminal, and notice you got a Qts of 1.15 or something, well, don't worry, par it and it drops in half, its just the configure
But basically it activates your speaker out on the USB, and your Mic in on the USB, and finds the variances in impedance while it does a quick tone sweep
these work fairly well, very handy if you are a box builder, great when used side by side with a great speaker box program
The software downloads in just a couple mins, and takes about 2mins to boot up. Dont forget to calibrate the unit with the 1k ohm resistor
This topic is now closed to further replies.
