teamsundown77 Posted April 27, 2009 Report Posted April 27, 2009 Ok guy i need some input, im going to be running a LVL 4xl 18 in my 2008 HYUNDAI ACCENT hatchback and want to know what config you would use on the box subs up port back or what?Also how many cubes should the box be 8-10 i want this box to play low but not to low, ie (GROUND POUNDER) My main goal is for the box to reek havoc on my car.
Decaf Posted April 27, 2009 Report Posted April 27, 2009 1) are you removing the trunk cabin area lid? 2) its 5-8cuft recommended 3) amp? 4) get your max dimensions first... that way its easier to figure out how much cuft and port you can have 5) likely port back sub up is good... both up can be good... and nightshade just proved sub back port up is too
oldschool Posted April 30, 2009 Report Posted April 30, 2009 It does not really matter as long as you use an audiopipe ampit will bang:drinks: TEAM GROUNDPOUNDERS INC. 156.5 OUT THE TRUNK OF A 95 CADDY W/1 SUB & 2AMPs score done on a termlab mic in the kick on the dash sealed was 154
teamsundown77 Posted April 30, 2009 Author Report Posted April 30, 2009 It does not really matter as long as you use an audiopipe ampit will bang:drinks: YOU CAN PUT SUNDOWN IN YOUR PIPE AND SMOKE IT AUDIOPIPE BOY!!
