bennett15 Posted May 1, 2009 Report Posted May 1, 2009 So when i got my FI i took out my old mtx 10's out of there box and ever since i took the one out it wont work at all the other one is perfect the both SVC 4ohms the run reads 4 ohm exactly and the other wont even get a reading? everything phyically looks intact aswell? Quote 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
white4d96 Posted May 1, 2009 Report Posted May 1, 2009 bad coil im guessing. Quote Too many projects, too little time...
bennett15 Posted May 1, 2009 Author Report Posted May 1, 2009 thing is it worked 100% before it came out of the box now its "dead" ever since it came out dont make sense? Quote 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
bennett15 Posted May 1, 2009 Author Report Posted May 1, 2009 bump need a fast solution or option boys Quote 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
white4d96 Posted May 1, 2009 Report Posted May 1, 2009 Double check your tinsels, set the DMM probes on them, see if that works. If so, maybe bad terminals. If not, maybe it was dead in box and you didn't notice it. Just a possibility. Was it stored in the enclosure? If not, maybe something hit it and broke the coil... Quote Too many projects, too little time...
uhoh_45 Posted May 1, 2009 Report Posted May 1, 2009 you sure it was working 100% before you took it out could be its been bad for a while and you just noticed it now Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
bennett15 Posted May 1, 2009 Author Report Posted May 1, 2009 sub was definitely working before seen it moving the night of. And ive tried touching the dmm on the tinsels and still nothing and they weren't stored in the box the night i got my FI i took them out of box and they sat in my room. the only thing i can think of is when i was taking it out it had gay interlocking clips on the end of the wires that connected it to the boxes terminals and i just yanked them out but terminal and tinsels look 100% Quote 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
uhoh_45 Posted May 1, 2009 Report Posted May 1, 2009 is it a common chamber box ? Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
bennett15 Posted May 1, 2009 Author Report Posted May 1, 2009 yeah they were wired down to 2 ohm each SVC 4 ohms and shared one chamber with a rear slot port that came out the passenger side Quote 98 Dodge Durango 12 000K 50/55W Headlights 12 000K 35W Fog lights HU Panasonic CQ-VX100 7" Reciever (1) Fi SSD 18" Fully Loaded (1) Ported box 33hz (1) Soundstream TRX1500D (1) Soundstream TRX2.440 (1) RE 6.5" Component Set (1) Rear battery Big 3 in 0/1 gauge 2 runs of 1/0 Gauge wire 250A Alt soon..
uhoh_45 Posted May 1, 2009 Report Posted May 1, 2009 if the sub was moving it was probibably the other sub pushing it in and out Quote R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
