uhoh_45 Posted May 1, 2009 Report Posted May 1, 2009 im looking into buying an astro and am looking into what i could do wall wize i just dont have the exact dimensions so if anyone has built a wall in an astro any info would be appreciated R.I.P! (Nov-29-2009) 92 explorer - 4 Atomic Apxx 15s duel .7s - 4rth order bandpass wall -4 powerbass XA-3000D's - 16 8volt batts wired to 16 volts - (9+/9-) runs 0gauge - 152.3 Db @ 29hz BUILD LOG current build 97 chevy lumina4 - 1 Atomic Apx 18 - 6 cube slot port trunk sealed off - 1 powerbass XA-3000D - 2 optima G31s in spare tire18 1 run 1/0 lumina build log
TechSys Posted May 3, 2009 Report Posted May 3, 2009 I'd have to take the measurements again, but I think 48" high x 50" wide x 72" deep That sound about right, but I can't be positive. The width can be a little bit wider if you take the top slider out. You should be able to fit anything you want in an astro/safari Team Pinnacle / Team SouthEastSPL / Team SoundStream / Team GPI / GPI Sales Rep for Florida and Georgia
