What Should I Do With This Extra 120mm Fan?
I have an extra 120mm computer fan that I bought years ago for my desktop build. My computer has 9 of these already and there's no more room to add this extra one.
Any idea if I can use this fan and hook it up somewhere for my amps?
http://www.petrastechshop.com/12yalod1blle.html
Specifications:
Model: D12SL-12
Fan Size: 120mm x 120mm x 25mm
Speed: 1250 +/- 10% RPM
Airflow: 38.5 CFM
Static Pressure: 0.8mm H2O (1.1mm H2O Max)
Noise: 25.4 dBA
Bearing: Sleeve
Voltage: 12 V
Current: .15 Amp Max
Fan Life: 20,000 hours
Connector: 3pin and 4pin pass-through connector
Description:
Petra's Tech is proud to provide a clear, UV Sensitive, blue LED version of the popular Yate Loon D12SL-12 120mm case fan. While utilizing the same D12SL-12 motor, this version offers a more attractive look with with its slightly blue tinted housing and 4 bright LEDs. Aesthetics aside, the LED model is actually QUIETER than the original version! The Yate Loon D12SL-12 LED is the obvious choice when it comes to performance, looks and price.
The Yate Loon D12SL-12 has an impressive CFM to noise ratio at only a fraction of the price of comparable fans. These versatile fans are constantly recommended for any 120mm application whether its on a heatsink, in a case, or even on radiators.
  • Who's Online   0 Members, 0 Anonymous, 1008 Guests (See full list)
