Whats A 70v Network? N How Does It Work?
i was lookin into some in wall speakers and outdoor speakers from partsexpress.com and seen some say, diff watts n then 70v setup, how does this work and what is needed for it to work? i was just wondering cause i like to learn some new things, n when we went to the beach they was a put put place that had jbl mids/highs with tic subs n it sounded awesome outside, it was the best outdoor speaker system ive ever heard, n sounded so rich n clean, n that Jamaican music they was playin had some lows in it to, i couldn't find those jbls anywere, not even on jbls site, but i seen tics in partsexpress n they look pritty cool
so does anyone kno what a 70v audio network is?
here's a link to my system 99 toyota tacoma , 2 mtx 8000 1504's in a sealed downfire , 1000w memphis amp
here's a link to my other system my 90 geo prizm test car
heres a thread i got of new songs u can dl that are legal = Some Good Bangage/you Can Dl These Free And Legit
70 volt systems are for like restaurants and stores where they have a shit load of speakers to run off the same amp.
First Gen Xterra: Always changing
DNX 690HD
RF 360.3
RF T3002
RF T4004
RF T10001bd
Silver Flute 6.5"s
Tang Band 1" Tweeters
Sundown X18 in 7cubes net tuned to 32hz
Trust me .25 Blows your Load.
i was thinkin that but ied like to kno how it works, or how it can go that low of ohms n what knot
The 70 or 100 volt 'constant' level is a myth. It is not a constant voltage level with adjustable amplitude or anything of the sort. What an installation 70V or 100V system is doing is using a step-up transformer (some amplifiers, like Crown Com-Tech's, DC's, etc etc need no transformer) to maximise the voltage output over current. A higher voltage transmission means that you can get the same amount of power a further distance on less copper. Each speaker then has a step-down transfomer to bring the voltage back down to a safe and usable level to drive said louspeaker.
The transfomers have a coil tap, in which the ouput windings can be selected giving an often wide choice of power output and resistance. A high voltage audio circuit often has resistance not measured in the usual multiples of two, as each loudspeaker is configured individually for power input using the coil taps.
DO NOT run a 70v system from a standard amplifier. Chances are your amplifier will let out the magic smoke, and once you let the smoke out it is very hard to get it to go back in. Likewise, do not run standard impedance loudspeakers on a 70v network too loud. They may not like the extra high voltage. Some will take it, some won't.
Cheers,
Mick
Work;
DiGiCo D1 Live / MIDAS Heratige 1000 / MIDAS Venice
Meyer Sound CQ-1's, CQ-2's, PSW-2's
RAMSA Monitor Amplifiers
P.Audio Monitors
BSS OMNIDRIVE and Soundweb
DBX 231 and Klark Teknik DN360 EQ's
RCF TT22A
RCF ART320
