thegreat22 Posted May 8, 2009 Report Posted May 8, 2009 Which puts more of a strain on alt. Pros and cons of extra battery or cap. I never plan on playing my system with the car off. Just trying to keep my voltage up. Big Three with Kicker Pkd1 coming monday. Stinger Voltmeter coming soon. 2001 Tahoe 2 Kicker Cvr's Dvc 4ohm wired down to 1 ohm Us Amps 4000 Xt and Crunch 1400 4 channel.
Guest KyleCannon Posted May 8, 2009 Report Posted May 8, 2009 Battery all the way. Caps are useless unless you have 0 voltage drop.
Neo_frog Posted May 8, 2009 Report Posted May 8, 2009 Well to answer the question, a battery would put more 'stress' on the alternator. Don't even bother buying a capacitor. A battery is the better choice. And before you go worrying about the alt, each battery only draws like 2A or something. One extra battery won't be detrimental to your charging effectiveness. Need an install? Hit me up.[email protected]Got car audio questions? Check here first!Everything you need to know. =]http://www.stevemeadedesigns.com/board/topic/83029-everything-you-need-to-know/
CaptainzPlanetz Posted May 10, 2009 Report Posted May 10, 2009 Well to answer the question, a battery would put more 'stress' on the alternator. Don't even bother buying a capacitor. A battery is the better choice.And before you go worrying about the alt, each battery only draws like 2A or something. One extra battery won't be detrimental to your charging effectiveness. That is unless you are pulling alot of current and draining the batterys and the alternator cant recharge both the batterys quick enough, which leads to premature failure of the alternator. But in the OP's case I dont think he will have a problem with the current draw of his system draining the batterys like that, so he will be fine with an additional battery. And dont buy a capacitor, they really only make a slight difference on systems with like 750rms or less, anything bigger look at doing the big3,H.O. alternator, and extra batterys(IMO in that order). ¿ǝɯɐƃ ǝɥʇ Trolls never learn............ All BS aside, If I see one more comment in here that is NOT about the pre-sale, I will start the vacations. And that includes the trolls feeding the trolls. YOU THE ONE THAT SOUND LIKE A OGER AND HUMPBACK/TROLLS? Add "SMDLIFER" on Xbox LIVE to play with other SMD members.
