Rogers Posted May 8, 2009 Report Share Posted May 8, 2009 yeah id take the line driver out and try it... or it might be a defective rca cable... Quote http://www.stevemeadedesigns.com/board/topic/79921-rogers-700-dream-car-update-page-17-a-wall/?p=2335774 93 Saturn SC2My system4 SA-15's Walled 2 Cerwin-Vega S2000's 3 Kinetik Hc2000's Dual 200amp alts. you guys done with the peepee touching contest or do I need to end it? Link to comment Share on other sites More sharing options...
RamenNoodles Posted May 8, 2009 Report Share Posted May 8, 2009 Dont pay $60 when you can do it yourself in a couple hours. Quote Diablo Audio Technologies Fi Car Audio Ascendant Audio Link to comment Share on other sites More sharing options...
neutman21 Posted May 9, 2009 Author Report Share Posted May 9, 2009 (edited) i put new rcas in and I had originally tried it without the line driver...im taking out the audiocontrol eq and crossover and adding just a phoenix gold line driver because I had low voltage before...line driver will be here monday.... and thank you for the note Red-navi.... Edited May 9, 2009 by neutman21 Quote THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK… Alpine CDA-9887 Audiocontrol three.1 JL Audio xd400/4 JL Audio C5-570 Components JL Audio C2-570x JL Audio hd750/1 JL Audio 12w6v2 Optima Yellow Top Viper 350hv Link to comment Share on other sites More sharing options...
HUMBOLDT_knock Posted May 10, 2009 Report Share Posted May 10, 2009 (edited) You need to start systematically ruling each component out! I would start with the sub, get one that can handle your amp and try to replicate the problem. If it doesn't do it then you know your Sub is F'ed. I would spend money on replacing components when you dont know if they are the culprit, you can waste lots of money doing it that way. Edited May 10, 2009 by HUMBOLDT_knock Quote Link to comment Share on other sites More sharing options...
neutman21 Posted May 11, 2009 Author Report Share Posted May 11, 2009 im getting my phoenix gold tld 22 line driver today...ill see if that helps my amp performance. i have read forums of people having alpine decks that put out low voltage from the sub out (mainly because you have to have the subwoofer control on the cd player turned all the way up to receive the 4 volts with a certain test tone). Ill see how it goes and post if it works or not...thanks for the help so far... Quote THE BASS KICKS AND THE HEADS TURN. THE STEERING WHEEL PULSES UNDER YOUR FINGERS AND YOU MORE THAN HEAR THE MUSIC, YOU FEEL IT. THE CRISP, CLEAR SOUND JARS THE COMPLACENCY FROM YOUR SOUL AND LEAVES YOUR PROBLEMS SCATTERED ON THE HIGHWAY UNROLLING BEHIND YOU. HERE IN YOUR CAR, YOU ARE KING. THIS IS YOUR WORLD, YOUR TIME, WHERE YOU ARE THE STAR AND YOU PICK THE SOUNDTRACK… Alpine CDA-9887 Audiocontrol three.1 JL Audio xd400/4 JL Audio C5-570 Components JL Audio C2-570x JL Audio hd750/1 JL Audio 12w6v2 Optima Yellow Top Viper 350hv Link to comment Share on other sites More sharing options...
