I have had my my 3000d since Feb. back when I was pushing a pair(2) of 12'' L7s. I never got hot. Just recently I have changed my subs to a pair(2) of 15'' DD 9500. Now my amp get hot. It went thermal once. I have the gain set at alittle over a half. Bass Boost to zero, Phase to zero, and subsonic all the way down. What would cause my amp to heat up? Do my subs need more power? Am I not giving my amp enough power? I still have a stock alt at the moment(I ordered a bigger alt with 200 amps). Two retop optimas. One has the main starting and the other in the trunk. I already did the big three. Any suggestions would really help.
Thanks.
2 DD 9515
1 Soundown SAZ-3000D
2 Optima Redtops
Big 3 upgrade
Hitting 151.1db
Forgot to add that the subs are wired to 1ohm
2 DD 9515
2 Optima Redtops
Big 3 upgrade
Hitting 151.1db
Thanks.
You need to tell us your headunit or gain doesn't help us.
You need a bigger alt, it takes power to make it, plus I would look at a better rear battery
Head Unit: Pioneer DEH-P6000UB
Sub Amp:American Bass VFL 500.1
Subs: 4 Fi BL 18's
Enclosure:21.5 Cubic foot flat wall tuned to 40 hz
Batteries: 3 Kinetik 2400's in the back, Kinetik 1200 under hood.
Mids & Highs: 4 Kicker DS 6.5 coax in doors, 2 Kicker DS coax in pillars
Highs Amp: Kicker kx250.2, kx100.2
Wire: 4 Runs 1/0 gauge Knukonceptz
Kenwood KVT-819DVD
Has far has the alt is concern I got that covered.
2 DD 9515
2 Optima Redtops
Big 3 upgrade
Hitting 151.1db
Heating up cuz low voltage and clip power...
Passport Build Here
Alarm: Prestige APS997A 2-Way/Remote Start
HeadUnit: Pioneer DEH-P6000UB
Front Battery: Yellowtop Optima D34/78
Back Battery: 2x C&D Technologies High Rate Series UPS12-475FR 134AH
Subs: 2x DC Lv4XL 18's
Amps: 2x Sundown Saz1500's Strapped
Box: 12Cubes 33hz 185sqin Port(15.4sqin per cube)
Pillars: AudioBahn AS31Q
Front Doors: Clif Designs TX40.5
Back Doors: Clif Designs CD50.4C
Rear Speakers: Clif Designs TX46.5
Front/Rear Amp: Kicker ZX350.4
Back/Pillars Amp: Kicker ZX200.2(Looking for another zx350.4)
Electrical: 1/0 Scorpion Wire 2 Runs Pos and 2Runs Ground, Knu 1/0 Flex Running to Amps ect, Big 3, JL 8Ga For Speaker Wire, Knu Karma RCA's, Scorpion Volt Meter
Deadener: 100 sqft Sound Destroyer Mat And SECOND SKIN Damplifier Pro Door Pack
Kenwood KVT-819DVD
5 volt deck, the amp takes 6v to .2v so at over half you are clipping it. Which I am guessing a voltage issue as well.
Subs: 4 Fi BL 18's
You called it. Its my crappy voltage. Now that I know what it is I can correct it. Thanks guys for the help.
2 DD 9515
2 Optima Redtops
Big 3 upgrade
Hitting 151.1db
  • Who's Online   0 Members, 0 Anonymous, 1594 Guests (See full list)
