check for leaks in the enclosure.
Also that port is retarded...whoever gave you that design sucks.
this.
sorry some1 gave you f*cked up dimensions
CURRENTLY UNDER RE-CONSTRUCTION
2008 Hyundai Sonata
Team T3 Audio
Team Deadly Hertz
Team SMD (Street Motivated Devastation)
Sorry not to good of an explanation but its 35 inches x 2 inches and bout 20 inches deep. Regardless of the would I be able to cut a new face plate and use it for 2 subs cause I got no subs and its killing me. Or wat other options do I have using the same enclosure
Edited by BlakSS
Your other option for that same enclosure would be to just seal it.
If you still have the manual for the cvr's it tells you what cubic feet per sub and port area you could use for them.
I have 3 12" comps in a ported box and my external dimensions are way bigger than what you have.
Atleast make the port 3''W no smaller, Are your subs dual 4ohm or 2ohm or 8ohm?how are they wired?I would geuss the box is your first problem.
