CEA 2006 Ratings :
Variable 40-4,000 Hz Low-Pass or High-Pass Crossover / 12 dB / Octave Butterworth Crossover Alignment Variable 35 – 70 Hz Bass EQ / Variable 0 – 18 dB Para-Punch Boost / Removable Connections Shroud 4 Gauge Power and Ground Connections / Built-In ATC Fusing / Preamp Outputs 1 Ohm Stereo / 2 Ohms Mono Stable / Wired Remote Para-Punch Bass ControlTRANS-ana design simplifies the input circuit path for optimal performance
MEHSA (Maximum Efficiency HeatSink Application) yields up to 5 times better heat transfer from the Mosfet devices to the heatsink Keeps the amp cool for increased efficiency and reduced distortion integrated PCB plenum, Custom designed TO-247 output Mosfets for thermal stability / Military Specification (Mil Spec) Glass Epoxy circuit boards.
Birthsheets:
http://forum.realmofexcursion.com/showpost...amp;postcount=3
refs on CA and ROE:
B,HCCAfan,B,TypeRBass,B,GalacticMonkey,
B,Mattz-us3-ike557,B,ROE,B,Angrytrucker78,
B,Stratusrt01,S,momentarylapse7,S,MTXThunder9500,
S,Audiobahnaholic,T,CoreyAnderson.
bought these new in jan 06, used them for 6 mos. Very nice amps.
ran one on a set of rf power 5 1/4 comp. and the other on my 2 subs @ 4ohms stereo.
both are painted by me, not a very good job but they are bulletproof amps functionally.
7/10 cosmetic 10/10 func. looking for 165 shipped ea.
Thanks
you sure you dont want to do that trade i meantioned? And after doin some thinkin i might trade one of those amps you were asking about. Just let me know.
Edited by lovellsz
RF Punch 40x2RF Punch 100x2RF Punch 200x2RF Punch 200x2RF Punch 400x4JL Audio 10W7-3"but its only a 200 watt amp tho"
or i can pay you a lil at a time until i pay it off. it would take me 2 weeks or so to pay it off fully, via paypal or i could send a money order, or check and you could holdem till they clear or w/e
shur can, pm sent.
1 traded, 1 left.
Price Droped to 150 shipped.
also looking for a 50ft spool of 1/0 kicker hyperflex power wire
for trade on the last one.
Thanks
Edited by ruger
PM sent
NoFearX18 said:
trainman0978 said:
oh and i meant to say whats the numbers on the one you had left...i saw the pic of the BS`s.
NoFearX18 said:
the one on top in the bs page, is the one i have left.
i also have a punch 150 limited edition for sale,
if you need a little more power.
pm sent.
pm sent.
PM sent back....i will take the T3002
NoFearX18 said:
trainman0978 said:
This topic is now closed to further replies.
