ok so i hear this term thrown around alot, but i still dont understand the full meaning or what casues it and what it sounds like and etc.. so if someone can explain it to me that would be great, THANKS
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
Sound waves are sine waves (remember that from trigonometry?) so they have curved peaks and valleys. Clipping cuts the tops and bottoms off of those waves and leaves squared-off areas in the waves. Which causes horrible sound, excess amp heat, and damage to amps, drivers, and so on.
Too many projects, too little time...
I've heard it described as sounding flat before. I have also heard that its hard to really notice unless you are tracking the wave with an oscilloscope.
@ high volumes it may sound like distortion. Most times you can't hear clipping unless it is really bad. A burnt glue smell from your subs is a good sign that you are clipping the hell out of them!
Jared Nixon  A.K.A. Jsmoke
My Car Stereo Website: 3rd Coast Customs
My Fishing Website: BigLake411.com
Add me as a friend: Myspace
Download: Check out my Audio Calculations Spreadsheet (Microsoft Excel)
ATTENTION ALL SMD MEMBERS: Do not under any circumstance buy anything from Chassistech! They do not stand behind their products & their customer service is horrible. They do not actually manufacture lowering springs, they drop ship them from Spring Tech. Chasistech.com also does business as Airbagit.com, Streetridepro.com & Truckinsuspension.com. They are all the same company! Do not trust these bastards! Their products are cheap & more often than not, you don't get what you actually order in the first place! YOU HAVE BEEN WARNED!
So is clipping casued by the song or the amp? i smell a lil smell maybe burning when i playing loud songs like Put on, Hyponitze, Put me in the Freezer.. etc..
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
same as distortion from an electric guitar just not as noticeable sounds alittle like stepping in snow if you know what I mean
previously known as wenn_du_weinst aka fucking internet coward supreme.  I talk shit on other forums like a little bitch and hope i don't get caught out on the street.
can be either more than likely you have your amp set to high
But the amps im using are sending less power then then RMS/ Peak can handle, 2000 peak 1000 RMS woofers, amps are sending 1500 Peak 600RMS... so in this case it would be songs right?
Re Audio
Diamond Audio
Alpine Audio
Rocksford Fosgate
DB Link
could still be the amp; when an amp clips, IIRC it sends more power than its rated for; which is part of why it's bad for an amp i'm guessing?
